Question Categories no longer appear in administrator
11 years 11 months ago - 11 years 11 months ago #160920 by funkmanusa
I had previously set up a bunch of categories and all was good after new install. They appear great on the front end. However, I decided to make a change to one of the category names and now, when I go to category manager, none appear... Even tried clearing filters, etc. However, if I add a new category, they are in the selection list of where I should assign the new category.
So how can I get the categories to appear in the category manager in the back end.
Thanks!
My Configuration report->
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 256M | Max file upload: 64M
Joomla default template details : yoo_organic | author: YOOtheme | version: 1.0.3 | creationdate: Unknown
Kunena default template details : RND Kelegant | author: Roundtheme | version: 1.2.0 | creationdate: 2014-07-25
Plugins: Search - Kunena Search 3.0.1 | Content - Kunena Discuss 3.0.1
Modules: Kunena Latest 3.0.1 | Kunena Stats 3.0.1 | Kunena Login 3.0.1 | Kunena Search 3.0.1
Last edit: 11 years 11 months ago by funkmanusa.
11 years 11 months ago #160935 by 810
look in the database if you can see them, if not you need to do it again.
11 years 11 months ago #160938 by rich
hm.. it seems a problem with the filter. In your filter is the setting "Access = Public". Change the setting from "Public to All."
Time to create page: 0.146 seconds
