Solved mobile kunena tabs
11 years 11 months ago - 11 years 11 months ago #160717 by mjind
mobile kunena tabs was created by mjind
Where do they go in mobile view? I mean I realize it probably has to do with being responsive. I just like how they look a step just before mobile. Is there a way to make it look more like that?
Last edit: 11 years 11 months ago by 810.
11 years 11 months ago #160719 by 810
Replied by 810 on topic mobile kunena tabs
Hi Jason,
its been resized by the css. kunena.responsive.css
11 years 11 months ago #160764 by mjind
Replied by mjind on topic mobile kunena tabs
Can I just disable those tabs for the small screen (mobile) ?
11 years 11 months ago #160765 by 810
it will loose your menu on mobile.
i suggest you will keep this, in the next version. K3.1 there will be a better responsive template.
The following user(s) said Thank You: mjind
11 years 11 months ago #160766 by mjind
810 wrote: it will loose your menu on mobile.
Thanks Jelle! I will wait! How's this looking? www.3dsignforum.com ? Thanks for your help..your letters are pretty much finished my son had to do some fine sanding on them and Melissa will be painting them very soon with the meta effects!
11 years 11 months ago #160768 by 810
yeah the site looks good, but you need to add emoticons. You guys is stilling using phpbb bbcode like ::lol:: you can add them, and select the right emoticon.
Ok thnx, will wait for them.
