Question Unable to click on or edit profile sections
11 years 11 months ago #160737 by 810
try to disable all none default joomla and kunena pugins, then enable it back one by one, until the one is breaking.
11 years 11 months ago #160738 by sozzled
nickza wrote: Seems to be a styling issue if anything, but that's just a guess.
I don't think it's a "styling issue". This looks more like a Javascript library conflict. See Common causes of Mootools (Javascript library) issues and Kunena
nickza wrote: Hope I dont have to change the template because that would disastrous.
I don't think it's that big a "disaster". The choice between whether you have a template that looks good or a forum that works is up to you. See Which came first? The template or the forum?
11 years 11 months ago #160976 by scaluca
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 128M | Max file upload: 25M
Joomla default template details : kallyas | author: Marius Hogas | version: 1.4.1 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.6 | creationdate: 2014-07-28
Plugins: None
11 years 11 months ago #160977 by scaluca
HI, I'm trying to turn on ftp lyier, ( and in the administration pannel under "server" it is show as "YES" ) but the problem persist....
Do yuo thing I have to change the TEMPLATE of the site... :pinch:
thank anyway your work it's GREAT!!!
Time to create page: 0.151 seconds
