Question Undefined property: KunenaConfig::$changename in...
New install Kunena 3.0.6 on Joomla 3.3.6 and Siteground.
The problem : in Kunena in frontend, between the category name and the subject, I have this error message :
Notice: Undefined property: KunenaConfig::$changename in /home/myaccount/public_html/mysite/components/com_kunena/template/orao/html/topic/edit.php on line 70
style="display:none;">
This line 70 :
<?php if ( $this->me->userid && !$this->config->changename && !$this->category->allow_anonymous ): ?>style="display:none;"<?php endif; ?>>
A solution ?
Orao is not from Kunena Team and it may not be quite up to date?
I hope the origin of this message will not be a problem later...
Problem hiding is not a solution(just my opinion)... problems need to try to resolve and that you do when you notify the manufacturer of Orao template?Django29 wrote: Thanks for answering, but the template Orao is more suitable for my website, and after I selected "System default" for Global configuration/Server/Error reporting, the error message disappeared.
All Kunena templates should work without errors if you set:
Global Configuration -- System -- Debug Settings -- Debug System -- Yes
Global Configuration -- Server -- Server Settings -- Error Reporting -- Maximum or Development
This is just my opinion...
I sent the message to the template editor too.
Good luck.Django29 wrote: I sent the message to the template editor too.
According to the website where people can still obtain the Orao template for K 2.0], this template made its appearance 2 years ago and it has not been updated for K 3.0.
You may be right that the Orao template is more "suitable" for your wbesite but I think you should also accept the fact that the template is not compatible with K 3.0 . There are many other templates that are available (at relatively little cost) that may be more suitable and that are compatible with K 3.0.
In the meantime, you have a problem with the Orao template and our recommendation is that you should use a template that is compatible with K 3.0. It really comes down to the question of what is more important to you: your forum or your template ?
