Question Poll options: Restrictive character limit
12 years 1 week ago - 12 years 1 week ago #160389 by sozzled
Kotsolis wrote: I use Kunena 3.0.6. with Joomla 2.5.14 and latest JomSocial version.
The current version of Joomla 2.5—at the time of writing—is J! 2.5.27; it might be a good idea to update your site to this version or migrate to J! 3.3. J! 2.5 support will cease at the end of this year.
I do not know what is the "latest" version of JomSocial that you are using on your website. It might help to watch the video vimeo.com/69818669 . At the time of writing, the latest version of Jomsocial available to the public is version 3.2.1.5. Is this the version you have installed on your website?
We have suggested several times that it might help if you posted your configuration report. Of course, you do not have to post your configuration report if you do not want to but, by the same token, it could take a very long time to help solve your problems without it.
Last edit: 12 years 1 week ago by sozzled.
12 years 3 days ago - 12 years 3 days ago #160501 by Kotsolis
SOS: NEED IMMEDIATE ASSIST!
I have 2 serious issues! Iam about to launch 2 polls in my forum. It's one of the biggest online contests, where users vote and then choose a gift. So I have very serious issues with both of those 2 polls that i want to open!
Those polls will have 43 poll options each! When I opened the first topic with the poll, I wanted the options to be alphabetically. Instead, I saw that some of the poll options were shuffled.
2nd thing is that the limit is still there in some options! Look at the video in 720p and full screen.:
First I show that the poll options are not alphabetically. In the 2nd part of the video I show that some of the poll options are cut!
I need an immediate assistance on this! There is no way that this is related to Joomla version. It's entirely a Kunena issue!
The contest starts in 1/12 and over 1.000 users participate each year so I need to find a solution immediatelly!
810 wrote: components\com_kunena\template\blue_eagle\html\topic\edit_editor.php line 97 change maxlength
maxlength="100" size="40" . It should not be cut!
Configuration report
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '-08-2014' at line 1 SQL=SHOW FULL FIELDS FROM jos_kunena_messages29-08-2014
Database collation check:
htaccess: Exists | PHP environment: Max execution time: 72000 seconds | Max execution memory: 2048M | Max file upload: 1024M
Joomla default template details : whiteboard | author: Opensource | version: 2.6 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.6 | creationdate: 2014-07-28
Third-party components: Jomsocial 3.2.1.4
Plugins: Search - Kunena Search 3.0.1 | JomSocial - My Kunena Forum Menu 2.0.3 | JomSocial - My Kunena Forum Posts 2.0.3 | JomSocial - Kunena Groups 2.0.3
Modules: Kunena Latest 3.0.1 | Kunena Search 3.0.1
Last edit: 12 years 3 days ago by Kotsolis.
12 years 3 days ago #160504 by 810
1) if you want alphabetic then you need to enter it alphabetic. In what order you enter, is not a kunena issue.
2) change the maxlength="100" to maxlength="300" or something. And check the width, with inspector or firebug, looks like the css is loaded from your joomla template, so you need to fix that.
Also update joomla, you are using a very old version.
12 years 3 days ago #160521 by Kotsolis
810 wrote: 1) if you want alphabetic then you need to enter it alphabetic. In what order you enter, is not a kunena issue.
The maxlength=300 didn't fix the issue.
Also the alphabetical order changes even if I add one field! Have you tested your poll with 50 options all alphabetically?
I don't think that it's a Joomla issue version. It's just a Kunena issue. You can login and check.
12 years 1 day ago #160559 by xillibit
In database structure it's allowed for 100 characters for the poll option
I never used a poll with more than 5 options, i will check where is the alphabetical issue
11 years 5 months ago #166115 by Kotsolis
Same bug in v4 .
You haven't fixed it. The poll character limit is 36 characters for me while the .php file says 100. Even the 80 doesn't work.
Time to create page: 0.155 seconds
