Question 'Offline/Online' tag always 'Offline'
12 years 2 months ago #158977 by billvv
We are using Kunena 3.0.5, having migrated from VB. Although the list of users online shows correctly, the tag in the message header never changes from 'Offline' for any user. Is there a setting in Kunena or Joomla that can activate this feature?
Is there a manual change to the database that I can change to activate this feature?
12 years 2 months ago #158984 by sozzled
I'm not quite sure I understand what you mean by "the tag in the message header". Before I answer your question, there are a couple of things I would like you to do for me, please:
1) It would be an excellent idea if you upgrade to K 3.0.6 ;)
2) Can we see your configuration report, please? (see the video vimeo.com/69818669 to learn more)
3) When you used the term "message header", did you mean >>> this <<< ?
12 years 2 months ago #158986 by billvv
Yes, that's the one. I'll update Kunena and if that doesn't do it I will post the configuration report.
Thank you.
12 years 2 months ago - 12 years 2 months ago #159129 by billvv
After a few days observation, it seems that the Offline/Online tag is correct when the user is a Joomla superuser, but not otherwise.
Is there a setting I'm missing to turn that feature on for all users?
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : gantry | author: RocketTheme, LLC | version: 4.1.8 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.6 | creationdate: 2014-07-28
Plugins: None
Last edit: 12 years 2 months ago by billvv.
