Question Language display
Now the thing i can't seem to figure out how to have the forum display in english too.
I've installed the component first, then the language pack. So i was under assumption when i change the joomla language through language module from nl to en, the forum GUI would swap to english too, however this is not the case. While joomla itself does swap to english, the front-end forum gui stays in nl, even if i specifically specify through user management that the users front end language is english?
Am i doing something wrong or am i missing something?
1) change forum menu item, set language to dutch.
2) copy menu item. then change language to English.
3) Create new menutype. like kunenamenu2
4) copy all menu items from kunenamenu. Use the batch.
5) Move all items (2) to kunenamenu2.
6) translate all titles to English.
7) go to forum menu item (English) and change Menu-item to load kunenamenu2 - forum.
9) same for kunenamenu to language dutch.
If you don't get to work. you can hire me for a hour. see ( www.jellekoksolutions.nl/ondersteuning )
My setup is like this
<nl root menu>
- support
-- forum (category list, selected category "hoofd forum")
<en root menu>
- support
-- forum (category list, selected category "main forum")
The problem now is that since i don't use the "home" menu, the kunena menu doesn't show up at all. First i need the kunena menu back under category listing. Then we can proceed.
oh and € 55 an hour? Thats like 5x what i make an hour, can't even remotely afford u. With clear instructions i can pretty much do things myself
Please try my way. You will see that is working.
Regards 810
PS 55 euro is just the start price. For you work, I just need 10 min. So you can also ask me fix other issues.
6) why is there a need to translate, i thought kunena was native englih and that the lang pack would take over
** edit ** also while the menu can be fixed that way, the forum content strings themselves such as "Total User Online" are still being displayed in nl-NL despite the fact that the test superuser specifically has both their frontend and backend language set to en-GB
