Solved Having problems
12 years 3 months ago - 12 years 3 months ago #158332 by TexasRovers
Having problems was created by TexasRovers
Sorry to bother every one. Did reinstall all looks fine now
Started this site a while back , it worked fine, now I get this error when I try to post to the forum
The requested page cannot be found.
An error has occurred while processing your request.
You may not be able to visit this page because of:
an out-of-date bookmark/favourite
a mistyped address
a search engine that has an out-of-date listing for this site
you have no access to this page
Home Page
If difficulties persist, please contact the System Administrator of this site and report the error below.
#1062 Duplicate entry '334-22' for key 'user_topic_id' SQL=UPDATE `k7qol_kunena_user_read` SET `topic_id`='22',`category_id`='9',`message_id`='36',`time`='1407599529' WHERE user_id='334'
here is the config file
htaccess: Missing | PHP environment: Max execution time: 50000 seconds | Max execution memory: 120M | Max file upload: 40M
Joomla default template details : beez3 | author: Angie Radtke | version: 3.1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 3.0.0 | creationdate: 2013-05-15
Third-party components: CommunityBuilder 1.9.1
Plugins: None
Last edit: 12 years 3 months ago by 810.
12 years 3 months ago - 12 years 3 months ago #158346 by xillibit
Replied by xillibit on topic Having problems
Kunena 3.0.0 is osbsolete you need to upgrade as soon as possible to 3.0.6 and it will fix the issue :
Last edit: 12 years 3 months ago by xillibit.
