Question Importing existing Users Avatar
12 years 3 months ago - 12 years 3 months ago #157737 by ponyack
We just installed the latest version of the forum. It seems that all our existing Joomla users are also associated with the forum so they can login.
But when they post a generic user avatar appears.
Is there a way to use a existing Joomla users avatar with the forum?
We also have a K2 forum on the site, would this be causing a conflict?
Thanks,
John
Last edit: 12 years 3 months ago by ponyack.
12 years 3 months ago #157738 by 810
Replied by 810 on topic Importing existing Users Avatar
Quick answer is no.
Kunena supports:
- AlphaUserPoints avatars
- Kunena avatars
- JomSocial avatars
- Community Builder avatars
- Gravatar avatars
12 years 3 months ago #157767 by ponyack
thanks for the reply.
So of the quick answer is no, would there be a method or process? Or is this something that each user must manually change via their profile?
12 years 3 months ago #157768 by 810
im sorry, I read something else.
What is your question exactly?
Is it changing the default avatar image?
- also change the images on \media\kunena\avatars\resized
12 years 3 months ago #157769 by ponyack
No Problem.
We were hoping to use existing K2 avatars with the Kunena Forum.
When you stated "Quick answer is no." I thought that there might be another not so quick way to import the existing avatars.
Basically the Kunena Forum recognizes the Joomla/K2 user in that, a user can login via the Kunena Forum using the Joomla/K2 login credentials.
But the Kunena profile does not update the avatar to match the existing Joomla/K2 avatar.
Is there a method to get the K2 avatar to the Kunena profile? Or do we just have to do it manual via the Profile section in Kunena?
Let me know if this makes senses
12 years 3 months ago #157770 by 810
No, we don't have integration with k2. So all users be manually changed by the profile - edit.
Regards 810
