Question How to enable tagging features
12 years 4 months ago #157319 by paeataa
I'm a noob, and wondered if anyone could tell me how to enable or disable tagging in forum for each new topic.
I'm using Kunena 3.0. When installing it and trying it out for the first time, I remember seeing a textbox that I can put 'tags' for each new topic. But now it's gone.
Thanks a bunch!
12 years 4 months ago #157353 by xillibit
I don't know where you had seen this textbox to add tags, but this feature need some extra to work. So it's disabled by default untill new improvements on it.
12 years 4 months ago #157483 by zydanielson
What "extra" is needed or required to make this work? I saw requests for tags in Kunena from three years back and that the feature was implemented in version 2. But either it wasn't, or I can't find it.
Anyone know the real status of tags for topics or posts?
"Life changes when you love what you love
more than you hate what you hate."
~ Elisha
12 years 4 months ago #157501 by xillibit
we had decided to use tags feature introduced in Joomla! 3.0 or 3.1 i don't remember exactly, we had waited a bit that the feature will be more stable. I can't say when this feature will be totally finished.
The following user(s) said Thank You: zydanielson
12 years 4 months ago #157513 by zydanielson
Okay, xillibit, thank you for the reply. Meanwhile, I've started making a small lightgray line at the bottom of posts and using a period in front of a tag word, or between words in a tag phrase. Like this:
.tagword .important.tag.phrase
The difference being that I make it color #dddddd and size 1 so you hardly notice it. But it's easy, then, to use the kunena search function to find ".tagword" or ".important.tag.phrase"
So I've found my workaround until the day. Maybe others will find this useful too.
~ Elisha
