Question Emoticons more button
  • Mariosgr
  • Mariosgr's Avatar Topic Author
  • New Member
  • New Member
12 years 5 months ago #157117 by Mariosgr
Emoticons more button was created by Mariosgr
I read that more button has been removed from kunena,
is it possible to create is ?
Forums with a lot of emoticons and/or big pngs for empticons become heavy.
Please explain me what is the difference with the emoticons bar checked and not checked,
creating emoticons with out to check the emoticon bar are useless because members have to know the code (that is not posted somewhere)
  • Mariosgr
  • New Member
  • New Member
12 years 5 months ago #157118 by Mariosgr
Replied by Mariosgr on topic Emoticons more button
Useful would be,
to be listed like the categories with option to rearrange their position.
12 years 5 months ago #157119 by sozzled
Replied by sozzled on topic Emoticons more button
Mariosgr wrote: I read that more button has been removed from kunena
Yes, this happened 3½ years ago when K 1.6 was released. This was discussed in the topic Button show more smiles in kunena 1.6
Mariosgr wrote: Forums with a lot of emoticons and/or big pngs for empticons become heavy.
That is probably true but the number of forums that have lots of emoticons are not common, either. If you look at the busy forums on the internet, you will probably find that most people do not use emoticons when they write. You will probably find that the number of messages posted that contain emoticons is less than 1% of all messages posted on the forum.
Mariosgr wrote: Please explain me what is the difference with the emoticons bar checked and not checked ...
See Smiley management in the Wiki.
12 years 5 months ago - 12 years 5 months ago #157120 by sozzled
Mariosgr wrote: Useful would be, to be listed like the categories with option to rearrange their position.
Does this have anything to do with the discussion about emoticons? :dry:
Last edit: 12 years 5 months ago by sozzled.
12 years 5 months ago #157134 by rich
Replied by rich on topic Emoticons more button
You can create a smiley scrollbar. Add at the end of your Joomla! template.css following code:
div#smilie { height:70px; overflow:auto; width:100%; }
The height is relative, depending on which Smiies you are using.
