Kunena 7.0.8 Released
Question Can not change order of some categories
12 years 3 months ago #156648 by korg007
I have no idea what I'm doing wrong.
I have categories under a section which I try to reorder by dragging the 3 dots/handle. As soon as I start to drag the sort handle, all my categories become grey and I can not relocate the category I'm dragging.
Any ideas?
Here's my config:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 10M
Joomla default template details : yoo_micasa | author: YOOtheme | version: 1.0.0 | creationdate: Unknown
Plugins: None
12 years 3 months ago #156687 by korg007
For those stumbling across this post, this can be replicated and is indeed a bug with Kunena Forum.
The workaround is to use PHPmyadmin and manually change the order of the Kunena-category table, the "ordering" field.
In the meantime, let's hope the developers fix this issue.
Cheers
12 years 2 months ago #156821 by xreliable
I confirm this bug as well.
Time to create page: 0.260 seconds
