Question Deleted Joomla user accounts appear in Kunena with wrong avatar
12 years 5 months ago #155845 by Frizzo
I have a weird issue where I have users that have been deleted in either Joomla or Jomsocial user managers but their posts still show up in Kunena.
The problem is, their profile pic that shows is the profile pic of the current user viewing the thread. So if I was viewing the thread it would show my profile pic on their posts.
Any ideas what is going on here and how to fix?
I have tried the Kunena Tools to remove deleted members but that does not fix it.
12 years 5 months ago - 12 years 5 months ago #155847 by sozzled
Kunena does not have the ability to delete users. If you delete users with the Joomla User Manager then you may problems if those accounts had posted messages on the forum. We do not recommend deleting user accounts for that reason.
Frizzo wrote: I have tried the Kunena Tools to remove deleted members but that does not fix it.
Which "Kunena Tools" did you use? Have you tried using the Kunena Synchronise Users feature in the backend?
Last edit: 12 years 5 months ago by sozzled.
12 years 5 months ago #156194 by Frizzo
Yes I tried the Synchronise users feature. Seems kind of odd I can't delete users as this is a necessary thing especially when using Jomsocial as members often delete their profiles and don't want to still be shown on the site. What can I do? Members are freaking out that their profile pic is appearing on other members posts.
12 years 5 months ago - 12 years 5 months ago #156200 by sozzled
I do not know anything about deleting users with JomSocial. Maybe someone else knows about this. I do not know what happens if you use the Kunena User Manager to delete users. When I delete user accounts I use the Joomla User Manager. If I delete a user account I then use the Kunena Synchronise Users tool (check all three checkboxes as shown in the following screenshot):
Is that what you did?
When you wrote that your users are "freaking out", it might help if you are a little quicker to reply to the topics that you write on the forum. We are trying out best to help you but it really would help a lot if we understood what you were talking about. Did you read advice printed at the top of this page?
12 years 5 months ago #156207 by Frizzo
Yes I have done that in Kunena Tools, weird thing is if I do all three and sync it says it deletes 174 users, then I click the recalculate statistics. After that do the sync with all three selected and it says it deletes 174 users again.
Here is the config report:
Database collation check: hwl3_kunena_pratings have wrong collation of type latin1_swedish_ci on field users_ip hwl3_kunena_pratings have wrong collation of type latin1_swedish_ci on field option
htaccess: Exists | PHP environment: Max execution time: 9000 seconds | Max execution memory: 1024M | Max file upload: 1024M
Joomla default template details : jsn_metro_pro | author: JoomlaShine.com | version: 2.0.2 | creationdate: Unknown
Kunena default template details : NTS KPraxis | author: Nice Theme Store | version: 3.5.0 | creationdate: 2013-12-24
Third-party components: Jomsocial 3.2.0.5
Plugins: Search - Kunena Search 3.0.1 | JomSocial - My Kunena Forum Menu 2.0.3 | JomSocial - My Kunena Forum Posts 2.0.3 | JomSocial - Kunena Groups 2.0.3
Modules: Kunena Latest 3.0.1 | Kunena Stats 3.0.1 | Kunena Search 3.0.1
12 years 5 months ago #156208 by sozzled
Thank you for your configuration report. It helps if you do this without prompting.
It sounds to me like you have some problems with your database tables but the very first things I would suggest that you do are
1) Uninistall the plugins JomSocial - My Kunena Forum Menu 2.0.3, JomSocial - My Kunena Forum Posts 2.0.3, JomSocial - Kunena Groups 2.0.3. These things do not work woth K 3.0.5. We have written about these things many times in this forum. See To what extent does K 3.0 support Jomsocial if you want to know more.
2) Fix up the collaton for the tables shown in red in your configuration report.
3) Discuss your problems with the author of the NTS KPraxis template that you are using or, if you would like to try it, use the K 3.0.5 Blue Eagle template instead. We do not answer questions about problems that people have with Kunena templates written by third-party developers.
If you continue to have problems, please post your updated configration report after you have made the changes that I have suggested here. Thank you and good luck.
Time to create page: 0.153 seconds
