- Thank you received: 22
Important Set kunena as homepage in K3.1?
- woonydanny
- Elite Member
Will you be able to set Kunena as homepage to your site with upcoming K3.1?
Currently in K3.0 this is not possible as it 'breaks' kunena.
still wish that i can write my forum signature through a jomsocial plugin and do it from my jomsocial profile
This claim relates to the topic Kunena does not work as my site homepage or with my Joomla menus which is a special case scenario.woonydanny wrote: Currently in K3.0 this is not possible as it 'breaks' kunena.
I have not had time to evaluate the issues brought up in your other topic. The claim that it is not possible to devise a Joomla menu item for K 3.0 and set that item as the default (i.e. "home page") menu item is unproven.
As far as K 3.1 is concerned, I am not aware of any issues that affect the ability to devise a Joomla menu item for K 3.1 in J! 3.2 and to set that item as the default (i.e. "home page") menu item.
- coder4life
- Kunena Contributor
- Thank you received: 50
- woonydanny
- Elite Member
It is pretty critical though for anyone that just wants to use joomla for kunena (ie and have kunena as homepage)
