- Thank you received: 1
Question General.css conflict with Kunena bbcode
- friday shoes
- Senior Member
that seems to messing with the ordered list and unordered list bbcode in Kunena.
If I disable the code in Firebug ordered and unordered lists appear as they should, but the menus on my website template gain a bullet point in front of each menu name.
Is there anyway I can just disable this code to stop it affecting Kunena but not the main site?
Best regards
- 9themestore
- Premium Member
If you want to disable in the Kunena and not the main site, you add prefix for each HTML element. Copy CSS rule below to the general.css file.
Regards
- friday shoes
- Senior Member
9themestore wrote: Hi friday shoes,
Code:#Kunena ol, #Kunena ul { list-style: none; }
Regards
Thanks for the suggestion, unfortunately it doesn't seem to make any difference, I can see in firebug that it strikes out the original code, but visually on the site it doesn't change anything.
I was wondering if it would be better to add overides (!important) to the kunena css? But not sure what ones values I would add it to.
- 9themestore
- Premium Member
Please post your url site here if your site has lived.
- friday shoes
- Senior Member
- friday shoes
- Senior Member
Here's what I put at the end of my general.css
