Question Notification emails not formatted correctly
12 years 9 months ago #152852 by billco
On the emails that are sent out after a user posts, the URL contains '&amp' instead of just '&', so they do not work.
Can you point me at a solution please?
Regards
Bill
Joomla! SEF: Disabled | Joomla! SEF rewrite: Disabled | FTP layer: Disabled |
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 10M
Joomla default template details : rt_cerulean | author: RocketTheme, LLC | version: 1.2 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.3 | creationdate: 2013-10-20
Kunena version detailed: Kunena 3.0.3 | 2013-10-20 [ Bifrost ]
Third-party components: CommunityBuilder 1.9 | UddeIM 3.2
Plugins: None
Modules: Kunena Latest 3.0.1 | Kunena Stats 3.0.1
12 years 9 months ago #152854 by 9themestore
I think, you should use the "&amp" character to replace the "&" character in your url.
Hope that helps
12 years 9 months ago #152874 by billco
Sorry, seems that the forum changed '
&amp
' to '&' in my original post
(how ironic - exactly what it should be doing when my site sends out the generated URLs in the notification emails, but it does not).
Any solution?
12 years 1 month ago - 12 years 1 month ago #159773 by Deepfreeze
Hello.
I too have come across the same problem with my notification emails sending out to users containing the following;
option=com_kunena&view=topic&catid=9&id=9782
and should read;
Any advise please.
Using Kunena 3.0.5
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 64M
Joomla default template details : expression | author: joomladesigns.co.uk | version: 3.0.1 | creationdate: Unknown
Third-party components: UddeIM 3.3
Plugins: None
Last edit: 12 years 1 month ago by Deepfreeze.
11 years 10 months ago - 11 years 10 months ago #161133 by thomasmanca
I use joomla 3.3.6. with Kunena 3.0.6 .. I have the same problem ...
Email notifications of new posts the "&" is transformed into "& amp;" .. the link does not work ..
htaccess: Missing | PHP environment: Max execution time: 120 seconds | Max execution memory: 128M | Max file upload: 25M
Joomla default template details : EsteticaSardegna2012 | author: | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.6 | creationdate: 2014-07-28
Plugins: Search - Kunena Search 3.0.1
Last edit: 11 years 10 months ago by thomasmanca.
Time to create page: 0.193 seconds
