Question Buttons not displaying "properly" in K 3.0.4
12 years 10 months ago - 12 years 10 months ago #152224 by mwvaadmin
Hi Guys,
Have just installed 3.0.4 in J2.5.17 and a lot of the User buttons on the Front End are not displaying correctly. Eg the "New Topic" button is displaying as "com_kunena_button_topic_create"
Config [strike]file is attached[/strike] below
htaccess: Missing | PHP environment: Max execution time: 3000 seconds | Max execution memory: 128M | Max file upload: 20M
Joomla default template details : yoo_revista | author: YOOtheme | version: 1.0.4 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.4 | creationdate: 2013-12-22
Kunena version detailed: Kunena 3.0.4 | 2013-12-22 [ Ukko ]
Plugins: None
Can you please advise?
Last edit: 12 years 10 months ago by sozzled. Reason: Reveal Kunena configuration report in message
12 years 10 months ago #152225 by 9themestore
If the button don't displaying correctly, I think you try to check the language file. (Try to re-install the Kunena component).
12 years 10 months ago - 12 years 10 months ago #152227 by sozzled
This website referred to in mwvaadmin's question has virus/adware issues; the website is unsafe until the malicious code is removed.
The question about displaying symbolic names on Kunena button labels has been answered before; see K 3.0 buttons display constant names . However, it is more likely that the forum button labels do not display correctly because your website has been compromised with a software virus which you need to fix.
