Question Bootstrap dropdown does not work on Kunena pages only
12 years 11 months ago - 12 years 11 months ago #151777 by pdolezel
Hi there,
Would anyone have any ideas on what I can check on to troubleshoot why a bootstrap-based dropdown works on all pages on a website, except on all Kunena pages. (I added a "My" button - when a user clicks on it, a dropdown reveals multiple actions/menu-like items ... see more here: getbootstrap.com/components/#btn-dropdowns ).
I saw no javascript errors (neither in Kunena debug nor in Chrome console) so it doesn't seem to be a Mootools conflict.
Since it works on pages w/ native Joomla components as well as with other components, I thought I'd post on Kunena's forum.
Thanks a lot for any pointers.
CONFIG REPORT:
Joomla default template details : rt_oculus | author: RocketTheme, LLC | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.4 | creationdate: 2013-12-22
Kunena version detailed: Kunena 3.0.4 | 2013-12-22 [ Ukko ]
Third-party components: UddeIM 3.2
Plugins: Search - Kunena Search 3.0.1
Modules: Kunena Latest 3.0.1
Last edit: 12 years 11 months ago by pdolezel. Reason: adding config report
12 years 11 months ago #151780 by 9themestore
Hi pdolezel,
You try to use the default Joomla! template. If it work fine, so reason of the rt_oculus template and if it doesn't work you need check the Javascript.
12 years 10 months ago #151827 by pdolezel
Thank you for the tip. The dropdown does work with Protostar on the forum/Kunena pages. So one could argue that it's clearly the template (although, it's really the combination of Kunena, RocketTheme template and the Bootstrap javascript ... hard to pin the blame on any one of these ... just happens to be the wrong combo I suppose ;-)
How would I check on the possible java conflicts? Joomla or Kunena debug does not provide any errors nor I see any in Chrome's Console.
Thank you for any additional tips. I will also post on RT's support forum.
12 years 10 months ago #151871 by coder4life
Although we try our best to make sure Kunena works in the many different environments it is likely to be installed in, sometimes unexpected situation can create this type of problem.
To help to find a possible error, make sure you have the google console open and debug activated. Reload the page with the debug console open, and try to perform the dropdown action to see if an error appears. An error will sometimes give you the line of Javascript where the error occurred. It is important to turn on Debug mode in any Joomla and third party extensions that implement their own debug mode. Without debug mode turned on, minimized versions of Javascript files are served, making line by line debugging difficult.
Rockettheme I believe uses a customized Bootstrap version and partial implementation of some of the CSS UI constructs. It might be the reason this issue is occurring. Hope this helps you where to get started.
Best Regards,
coder4life
12 years 10 months ago #152454 by pdolezel
Thank you for the reply. So after some hefty research and lots of help from RocketTheme, here's the bottom line:
jQuery and Bootstrap JS files (which power the drop-down I'm trying to implement) are not loaded on the Kunena pages while they do load on all other pages. The RocketTheme relies on Joomla's libraries to load the jQuery, it's not their template loading them directly.
Can you, guys, give me a hint why jQuery is prevented from being loaded on the Kunena pages?
Appreciate any pointers. Thx, Pavel
12 years 10 months ago #152457 by tracejustice
It seems the Kunena menu isn't outputting the "active" class. I am having problem with the Forum not hightlighting when active like the rest of my pages do.
Time to create page: 0.145 seconds
