- Thank you received: 1
Question Finder (Smart Search) Plugin
Is this an oversight or is there a specific reason such as it doesn't work?
I thought I would ask the question before I attempt to manually install it and test it myself.
I have searched the forum for an answer and saw a similar question in an earlier release but no answer was given.
- Jiminimonka
- Elite Member
- YBAS!
You can install and enable the plugin manually, but be warned that it isn't always able to keep the index up to date and there's no guarantee that it even works. Also it hasn't been integrated to Kunenas own search yet.
Because of the issues with smart search index size I've been investigating other solutions for the search issue together with RocketTheme.
A shame really because there are some definite benefits using the finder (smart search) rather than the standard search mechanism, just that the headaches outweigh the benefits.
