Solved Images not uploading
12 years 11 months ago #151471 by alanhome
Hi all, Kunena 3.0.3 on Joomla 3.2. I'm unable to upload image attachments from the frontend--I'm able to click "Add File" and select images from my hard drive, but nothing is uploading. Any suggestions?
Thanks in advance!
Configuration report follows (with my domain/URL/email info deleted):
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 20M
Joomla default template details : yoo_moreno | author: YOOtheme | version: 1.0.4 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.3 | creationdate: 2013-10-20
Kunena version detailed: Kunena 3.0.3 | 2013-10-20 [ Bifrost ]
Third-party components: AlphaUserPoints 1.9.2 | Jomsocial 3.1.0_RC1
Plugins: JomSocial - My Kunena Forum Menu 2.0.3 | JomSocial - My Kunena Forum Posts 2.0.3 | JomSocial - Kunena Groups 2.0.3
Modules: Kunena Latest 3.0.1
12 years 11 months ago #151476 by Bossman45
I can select the Add File button and the upload dialog box appears and allows me to select an item. I can select insert but it only adds the text. When you look at the post nothing is visible. How can this be resolved?
12 years 11 months ago #151480 by coder4life
Please change your default template to Joomla Protostar and see if you have the same issue.
Please also provide details about the extension/type of file and size.
12 years 11 months ago #151481 by alanhome
Hi,thanks. So I just tried again, I think it's a css issue. Here's why:
I create a new forum topic, click "Add File" and select a jpeg from my hard drive, but Kunena does not show that anything is in the attachments list. But when I submit the new topic, the image appears as an attachment for the new topic.
Kunena is uploading attachments, but is just not showing any list of attachments as they are selected. (before submission) My submission template looks EXACTLY like the template we're using here on this forum, just darker. Any thoughts on what might be affecting this?
I'm using the Blue Eagle template, and made the following mods to the CSS files: change user type colors (blue_eagle/css/kunena.skinner.css AND blue_eagle/css/kunena.skinner-min.css), removed forum breadcrumbs (blue_eagle/html/display.php), and removed subcategories from the forum home (blue_eagle/css/kunena.skinner.css AND blue_eagle/css/kunena.skinner-min.css).
12 years 11 months ago - 12 years 11 months ago #151482 by alanhome
IT'S NOT A CSS ISSUE, it's a Kunena backend thing
FYI to Kunena developers, if you set Configuration > Frontend > "Limit Attachments" to 0, frontend users can still upload attachments, but they don't show up on any attachments list. Maybe this was the way it was designed, but seems a little confusing. (and I was using 0 because my other components use 0 as an unlimited quantity setting) Either way, if 0 is the setting, uploads are still possible.
This issue is closed for me, thanks!
Last edit: 12 years 11 months ago by alanhome.
12 years 11 months ago #151521 by Matias
Time to create page: 0.145 seconds
