Question Cell Frame/Divide for [table] is not visible
12 years 11 months ago #151080 by Plaetzchen
Hi there,
for some reason I cannot figure out, the frames of the cells of the table BB-Code are not displayed anymore. They were up until 2 days ago. Today I noticed they were gone.
Only change I did was changing color of text and links in the css. Naturally I assumed it had somethign to do with this, but reversing the changes did nothing, frames ware still gone.
Hope somebody can help me.
Cheers!
htaccess: Missing | PHP environment: Max execution time: 90 seconds | Max execution memory: 128M | Max file upload: 64M
Joomla default template details : protostar | author: Kyle Ledbetter | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.3 | creationdate: 2013-10-20
Kunena version detailed: Kunena 3.0.3 | 2013-10-20 [ Bifrost ]
Third-party components: CommunityBuilder 1.9 | UddeIM 3.1
Plugins: None
Modules: Kunena Latest 3.0.1
12 years 11 months ago #151083 by 9themestore
Hi Plaetzchen,
I think there are two reasons for your issue.
1. Your java script is very old.
2. There is conflict CSS with joomla template or third party extensions.
You try to re-check your site with two above reasons.
Regards,
