Solved No topics but 3 replies
13 years 4 weeks ago - 13 years 4 weeks ago #149936 by cwjs
No topics but 3 replies was created by cwjs
I have just set up my forum (3.0.3) I have created thre categories and posted OK in two but the third one is no topics and three replies, it should be should just two topics.
As an attachment, I have included and error.png showing the problem and the configuration report you ask for.
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 10M
Joomla default template details : myarchcomplete | author: | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.3 | creationdate: 2013-10-20
Kunena version detailed: Kunena 3.0.3 | 2013-10-20 [ Bifrost ]
Third-party components: CommunityBuilder 1.9
Plugins: None
Clive
Last edit: 13 years 4 weeks ago by sozzled. Reason: Reveal Kunena configuration report in message
13 years 4 weeks ago - 13 years 4 weeks ago #149994 by Mortti
Replied by Mortti on topic No topics but 3 replies
This can be related of my very old issue report(with Review posts), but I want that the developers check it.
github.com/Kunena/Kunena-Forum/issues/1367
In your case is interesting because look like that SU,admin or global moderator has done those topics at first?
Last edit: 13 years 4 weeks ago by Mortti.
13 years 4 weeks ago #150015 by cwjs
Replied by cwjs on topic No topics but 3 replies
Thank you Mortti,
following what you implied I went in as admin (full admin) amd moderated clive (also showing as an admin in kunena but only a registered user in joomla) I found there were 4 posts two real and two deleted (showing a bin). I permanately deleted the two in the bin and the topics now show up as they should.
I think the developers do need to look at this as it does seem to be an issue.
Thanks again
Clive
The following user(s) said Thank You: Mortti
13 years 4 weeks ago - 13 years 4 weeks ago #150017 by sozzled
Replied by sozzled on topic No topics but 3 replies
cwjs wrote: ... I went in as admin (full admin) amd moderated clive (also showing as an admin in kunena but only a registered user in joomla) ...
This does not make sense. A user cannot be forum administrator (with forum administrator privileges) if they are not a member of the Joomla adminstrators group. Perhaps you are confusing forum administration privileges with Kunena forum ranks?
There is only one class of users who can permanently delete topics: site administrators (accounts that are members of the Joomla administrators group). Forum moderators can delete topics but those records are not removed from the database. Moderators cannot permanently delete topics.
Deleting topics that are waiting for someone to approve them is not recommended. It is better to approve (or not approve) topics that are awaiting review and then to delete them (if that is what you really want to do).
13 years 4 weeks ago - 13 years 4 weeks ago #150019 by Mortti
sozzled wrote:
cwjs wrote: ...
SU = Super User in J! 3.1.5 > is the last point, depands of your settings... everything can delete... but when you need that back... talk to server provider or look your backups ;)
Michael talk right of permissions... and wait what developers says in this case.
13 years 3 weeks ago #150024 by Matias
Replied by Matias on topic No topics but 3 replies
Yes, it makes sense that deleting a topic fixes the issue as it does full recount on the category statistics.
You could have done the same by using Forum Tools -> Recount Statistics feature.
Doesn't fix the issue, though. :( But it gives me a pointer that there could be off-by-one update on some delete, either deleting topic or a post.
Time to create page: 0.159 seconds
