Question K 3.0.3 meta description for replies
13 years 4 weeks ago - 13 years 4 weeks ago #149912 by ssh
Problems with Kunena 3.0.3 meta description for replies
Kunena is creating duplicate meta description on every reply to any post.
For example:
##New Topic
Topic: Example Topic (1/16)
Description: Example description for topic (1/16)
#Reply1
Topic: Example Topic (2/16)
#Reply2
Topic: Example Topic (3/16)
#Reply3
Topic: Example Topic (4/16)
NOTE: This issue is generating to many errors on google webmaster tools
Last edit: 13 years 4 weeks ago by ssh.
13 years 4 weeks ago #149915 by sozzled
Please see K 3.0 Meta Description Generators . I hope that helps.
Next time you post a message in the support category, please read the rules .
*** Topic icon changed and topic moved to different category by moderator ***
13 years 4 weeks ago #149938 by ssh
Thanks,
but I am already aware about these changes in the meta description generator.
The problem I am posting is related but is different.
The new changes to the meta description generator only applies for posts, not for the replies, and all the replies are published using the same meta description as the original post.
any idea?
Thanks in advance,
13 years 3 weeks ago #150105 by xillibit
How do-you want change the description tag for replies which are on the same page ?
13 years 3 weeks ago #150133 by ssh
no need to change the same page, but at least change it in the replies that are on a separate page.
In my case, I have this:
$ this-> messages_per_page = max ($ this-> messages_per_page, 1);
kunena forum ==> Configuration ==> frontend ==> Look and Feel ==> Messages Per Page = 1
It turns out that each page duplicates the description of the original post, and what I would like to do is to take its own description, if one member responded to the issue by saying "I work for a large company located in Latin America" this sentence is the description .
13 years 1 week ago #150743 by ssh
What I mean is that if every reply is indexed like a single page, it will significantly improve the seo performance of the site.
