Question Kunena 3.0.2 Members of the previous posts and unapproved post.
12 years 6 months ago - 12 years 6 months ago #149521 by asukasan
English is a little bad, so I apologize to you guys.
hello friends.
Using 1.7.2 version of Kunena Forum has 1.5 years.
1 week ago Kunena Forum 2.0 upgrade, then upgraded version of Kunena Forum 3.0.2.
3.0.2 version of Kunena Forum has been having problems after the transition, the second largest.
* Part of the previous posts I do not see a registered user profile.
"More" section click on "do not post" I get the message. (Although there are many more message)
* Kunena Forum 1.7.2 version of the user's profile and when I enter any unapproved messages could see. After the upgrade version of Kunena Forum 3.0.2, but I don't see that there is unapproved the message. (although many unapproved posts)
Thank you in advance for your help.
Last edit: 12 years 6 months ago by asukasan.
12 years 6 months ago - 12 years 6 months ago #149522 by asukasan
configuration report
htaccess: Exists | PHP environment: Max execution time: 3000 seconds | Max execution memory: 2048M | Max file upload: 128M
Joomla default template details : beez_20 | author: Angie Radtke | version: 2.5.0 | creationdate: Unknown
Kunena default template details : Flat (Quick reply at page bottom) | author: DesignExpo | version: 1.7.0 | creationdate: 2011-08-29
Third-party components: UddeIM 3.1
Plugins: None
Modules: Kunena Latest 3.0.1
Last edit: 12 years 6 months ago by sozzled. Reason: Remove spoiler from configuration report
12 years 6 months ago #149538 by sozzled
You are using an unsupported Kunena template.
The following user(s) said Thank You: asukasan
12 years 6 months ago #149570 by asukasan
Thank you for your interest.
Kunena Forum has used the default template.
I will make a fresh installation trial
Time to create page: 0.283 seconds
