Question Allow Guests to Post/Write
13 years 1 month ago #149378 by Fox
Does the option Allow Guests to Post/Write, under Configuration > Security still works on Kunena 3.0 series?
It seems that even when enabled, guests don't see neither the button "new topic", nor "reply" and they are unable to post.
It is confirmed?
- Demis Palma -
13 years 1 month ago - 13 years 1 month ago #149414 by sozzled
Replied by sozzled on topic Allow Guests to Post/Write
Fox wrote: Does the option Allow Guests to Post/Write, under Configuration > Security still works on Kunena 3.0 series?
Yes, the configuration option works the same way in K 3.0 as it did in K 2.0.
Fox wrote: It seems that even when enabled, guests don't see neither the button "new topic", nor "reply" and they are unable to post.
If this is the case, maybe you changed something? You should search this forum for "new topic" in the subject and maybe you will find the reason why things are not working for you.
Last edit: 13 years 1 month ago by sozzled.
