Question My forum appears as if there is no template
13 years 2 months ago #148704 by Maritrice
My forum is appearing as if there's no template (screen cap included), has anyone else had similar bugs?
When I first installed the kunena forum to my site a few days ago it worked perfectly with the blue eagle 2.0 template. But when I checked on the site yesterday morning it looked as it does now, even though I didn't make any changes.
I tried using the Orao - Kunena 2.x template but it doesn't change anything.
I'm using Kunena 3.0.2 and Joomla 3.1.5 Stable.
Does anyone know what might have caused this or how I might fix it?
I've tried clearing the cache and removing the menu item and then restoring it via the Kunena control panel.
I'm totally new to joomla and a rookie to webdesign in general so please bear with me if I ask any silly or obvious questions.
13 years 2 months ago #148709 by Jiminimonka
Please post your Kunena Configuration Report.
Please read the FAQ.
Only one question per topic.
13 years 1 month ago #149099 by siao
Hello!
I have same problem
configuration:
htaccess: Missing | PHP environment: Max execution time: 305 seconds | Max execution memory: 256M | Max file upload: 200M
Joomla default template details : yoo_solar | author: YOOtheme | version: 1.0.1 | creationdate: Unknown
Kunena default template details : Orao - Kunena 2.x | author: www.TemplateKunena.com | version: 1.0.3 | creationdate: 15.12.2012
Plugins: None
13 years 1 month ago - 13 years 1 month ago #149118 by sozzled
G'day, siao, and welcome to the community.
The third-party Kunena template that you are using was not designed or developed by the Kunena project team and, looking at the date when the template was created, it was written for a much older version of Kunena. It probably does not work with K 3.0.2. If you are having problems with this template we suggest that you take this matter up with the developers of that template. Alternatively, use the Blue Eagle template instead.
Good luck.
Last edit: 13 years 1 month ago by sozzled.
The following user(s) said Thank You: siao
