Question Is it possible to automatically update to Kunena 3.0.2?
12 years 9 months ago #148069 by donkey12
Hi there,
We're using Kunena 3.0.1 on a Joomla 2.5.14 site.
We'd like to update to Kunena 3.0.2.
Is there is a way of doing this automatically from Joomla Extension Manager Update?
12 years 9 months ago #148070 by sozzled
This is only my personal opinion but I think it's safer if (until the problems with Joomla have been solved) you upgrade using the method described in K 3.0 Upgrade Guide .
The following user(s) said Thank You: donkey12
12 years 9 months ago #148074 by Jiminimonka
Eventually it will be, but at the moment it is disabled while some issues are being resolved.
Please read the FAQ.
Only one question per topic.
12 years 9 months ago #148090 by flaminga
I have been trying to upgrade my version of Kunena and I get the following error message.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 10M
Joomla default template details : ca_cloudbase2_j25 | author: CloudAccess.net | version: 2.0.6 | creationdate: July 27, 2011
Plugins: None
12 years 9 months ago - 12 years 9 months ago #148091 by sozzled
*** Topics merged ***
Instead of using the "Live update method", try using the method described in K 3.0 Upgrade Guide B)
Last edit: 12 years 9 months ago by sozzled.
The following user(s) said Thank You: flaminga
12 years 9 months ago #148269 by donkey12
Thanks Jiminimonka & sozzled,
I'm happy to wait until the issue with Joomla is resolved and automatic update is available.
Time to create page: 0.273 seconds
