Question Something went wonky with page layout?
13 years 4 months ago - 13 years 4 months ago #146096 by RCheesley
Hi folks,
I'm not entirely sure what has happened but our forums appear to be broken since we migrated to 3.x. It was working fine straight after the migration (cached, perhaps?) but now very odd:
www.viryasoftware.com/forum
Not had this kind of problem happen before, not really sure where to start! It appears none of the site markup is there at all (navigation structure etc) it just jumps straight into Kunena.
Ruth
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 600M | Max file upload: 8M
Joomla default template details : Virya Software | author: Virya Software | version: 1.0 | creationdate: Unknown
Kunena version detailed: Kunena 3.0.1 | 2013-06-29 [ Noordwijkerhout ]
Third-party SEF components: sh404sef 4.1.0.1559
Plugins: None
Modules: Kunena Latest 2.0.4
Last edit: 13 years 4 months ago by RCheesley. Reason: Report included
13 years 4 months ago - 13 years 4 months ago #146097 by RCheesley
[strike]Not sure if it's related to www.kunena.org/forum/kunena-3-0-support/...ange-broken-template as we use RokBox.[/strike]
The moment I disable RokBox I'm back to normal.
Did you get anywhere with speaking to them?
Ruth
13 years 4 months ago #146105 by sozzled
G'day, Ruth :)
It would be a good idea to use the Blue Eagle template designed for K 3.0 instead of the one designed for K 1.7.2. Also, you should update the Kunena Latest module.
I don't know about Rokbox. I'm fairly sure that we're not using it on this site. Have you spoken/corresponded with Rockettheme ?
