Sticky How do I change the "default view" of the forum from Recent Topics to Index?
13 years 2 months ago #146086 by MikeFromHC
This forum opens with "Index" selected when it opens.
Mine opens to "Recent Topics"
I can't find anyplace to change this.
The following user(s) said Thank You: jthrongard
13 years 2 months ago #146087 by sozzled
G'day, Mike, and welcome to the forum.
This is one of those frequently asked questions (it's a good idea to look at the FAQs tab on the menu near the top of this page for these things) and it's easily resolved by looking at How do I change the "default view" of the forum from Recent Topics to Index?
13 years 2 months ago #146339 by MikeFromHC
sozzled wrote: G'day, Mike, and welcome to the forum.
I read that and have spent some time trying to do it.
I have looked through users and general to see if there is a place to indicate which tab is selected at start up and found nothing.
The menu itself shows, and has always shown "Index" as the first item. I have set the order to both "Index" and "First" (Joomla 3.0)
The ordering is set to ascending and all other menus follow this order.
Nothing I have done has changed the fact that "Recent Topics" is selected when I open the page as any user with any access levels.
13 years 2 months ago - 13 years 2 months ago #146340 by 810
Go to your Joomla backend.
If you are using J! 3.x:
Menus » Kunena Menu » Forum » Details » Default Menu Item = Index
If you are using J! 2.5:
Menus » Kunena Menu » Forum » Required Settings » Default Menu Item = [ kunenamenu ] Index
(Off-topic for K 3.0 but included for completeness for K 2.0 users) If you are using J! 1.5:
Menus » Kunena Menu » Forum » Parameters (basic) » Default Menu Item = [ Kunena Menu - Top ] Index
regards 810
Last edit: 13 years 2 months ago by sozzled. Reason: Add information for different flavours of Joomla
The following user(s) said Thank You: hllyyc
13 years 2 months ago - 13 years 2 months ago #146341 by sozzled
The following user(s) said Thank You: checksum, Vasyekv
13 years 2 months ago #146893 by sozzled
We assume, after a couple of weeks without a response, that this question has now been resolved. :)
Time to create page: 0.215 seconds
