Merged ERROR unapproved posts, not show k3.0
13 years 5 months ago - 13 years 5 months ago #145478 by DaTOkz
hello,
I have a problem not approve messages do not appear, please look at the pictures:
here alert - 6 messages.
here no posts.
No subcategories, what is the problem?
Thank you.
Last edit: 13 years 5 months ago by xillibit.
13 years 5 months ago #145492 by xillibit
can-you post here your kunena report configuration settings ?
13 years 5 months ago - 13 years 5 months ago #145510 by DaTOkz
xillibit wrote: Hello,
ok look here:
[/quote]
Joomla default template details : | author: | version: | creationdate:
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 3.0.0 | creationdate: 2013-05-15
Third-party components: UddeIM 3.0
Plugins: Search - Kunena Search 3.0.0
Modules: Kunena Latest 3.0.0 | Kunena Stats 3.0.0 | Kunena Login 3.0.0
thanks.
Last edit: 13 years 5 months ago by DaTOkz.
13 years 5 months ago - 13 years 5 months ago #145513 by sozzled
Perhaps, if you simplify your menu (as shown in the article Kunena Menu issues ) you will not have the problems that you are having now? :unsure:
It might also be a good idea to tidy the database collation attributes, too. ;)
Last edit: 13 years 5 months ago by sozzled.
13 years 5 months ago - 13 years 5 months ago #145516 by DaTOkz
sozzled wrote: Perhaps, if you simplify your menu (as shown in the article Kunena Menu issues ) you will not have the problems that you are having now? :unsure:
then the problem is the menu? disable the default kunena menu, ok im check and delet menu's.
13 years 5 months ago - 13 years 5 months ago #145518 by sozzled
What is always a good idea, when people have problems - and many of these problems are the result of trying to do this in ways that we do not recommend - is "get back to the basics".
I did not say that these problems (with unapproved posts not displaying on your site) are caused by the menu. I did, however, write that it's a good idea to use the standard Kunena menu instead of the menu that you are using. It is also a good idea to disable plugins where you do not require those plugins.
Let's try to get back to the simplest kind of environment that you can get and work from there. :)
Time to create page: 0.157 seconds
