Question "Component not found" error message
13 years 5 months ago #145369 by jaylartey
Just installed the latest version on joomla 2.5, all is good but when i click on the Board Categories im getting errors. Be i had Kunena then installed EasyDicussion now i have reinstalled Kunena again which is the latest version.
jos-Error: Component not found
JSite -> dispatch() @ /home/*******/public_html/index.php:42
JComponentHelper :: renderComponent() @ /home/********/public_html/includes/application.php:197
JError :: raiseError() @ /home/*****/public_html/libraries/joomla/application/component/helper.php:337
JError :: raise() @ /home/******/public_html/libraries/joomla/error/error.php:251
Could someone kindly help with the above??
Many Thanks
totallyhired.com jobs
13 years 5 months ago #145376 by xillibit
It seems that Kunena is mis-isntalled on your system, the error that you are quoting in your message doesn't give any clue. Try to reinstall Kunena
13 years 5 months ago - 13 years 5 months ago #145381 by sozzled
jaylartey wrote: Just installed the latest version on joomla 2.5, all is good ...
If "all is good" (in the backend) then you should be able to produce a configuration report. Please read the terms of use , in particular section 7.3 of those terms. Thank you.
I agree with xillibit. I do not think you have properly installed K 3.0 on your Joomla website.
Last edit: 13 years 5 months ago by sozzled.
