configuration report
Question Only permit download of attachments for registered users
13 years 4 months ago #144796
by barbed
Only permit download of attachments for registered users was created by barbed
hi
i want know how i can access to post for just register user can download attache file's in post's.
i want public users can see the post but when click on the attache files thay can't download first register and than can download the file's!
what must i do?
thanks
what must i do?
thanks
13 years 4 months ago #144799
by skybax
Replied by skybax on topic Only permit download of attachments for registered users
In Kunena Forum: Configuration >> Uploads >> Show Attachments for Guests: No
Set to Yes if you want to show attachments for guests.
they can see the post but not the file until they login
13 years 3 months ago #144907
by PoiTaL
Replied by PoiTaL on topic Only permit download of attachments for registered users
Hi guyz!
My question are same. public user can see the attache file but until they loged in can't download the files. I tired to find out this configure
13 years 3 months ago #145178
Replied by sozzled on topic Only permit download of attachments for registered users
This question has been asked many times before.
Attachments in Kunena are not protected by the kinds of security mechanisms that exist in some other Joomla extensions (e.g. Remository ).
Basically the answer is this: if a link to an attachment is visible on a web page (if the link is to an attached file in a Kunena forum message) then you can click the link. After you click the link there is no interception to determine if you have the access rights to take further action.
In other words, if you can click it, then you can download it.
11 years 6 months ago #162521
by AndreyS
Replied by AndreyS on topic Only permit download of attachments for registered users
How to make so that the attached file was not available to all the direct link to download, and registered users only?
After all, there is little point in options to hide attachment from the guests if they can download the file from a direct link.
How is it possible to adjust / correct please tell me!
Thanks!
V.3.0.7
Thanks!
V.3.0.7
11 years 6 months ago #162523
by 810
Replied by 810 on topic Only permit download of attachments for registered users
In K3.0.7:
If users know the direct link, they can download it
In the next big update K3.1:
we have added protected attachments
Time to create page: 0.260 seconds
