Solved Writing topics always with underscore
8 years 10 months ago #1 by uolly78
Hello to all!
Every time I write a topic or a reply in my Kunena, the text is always underscored. When the topic is published it is written correctly but when I edit it is underscored (see attached screenshot)
why?
can someone help me?
Joomla! 2.5.27 Kunena 2.0.4
8 years 10 months ago #2 by 810
Sorry Kunena 2, is not supported anymore, please update to K4.0
The following user(s) said Thank You: uolly78
8 years 10 months ago #3 by uolly78
Hello I have tried to update many times but the installation fails and blocks ALL THE SITE (when i type my site urls both for front end and administrator i get a completely white page after update). To restore it i have to use a backup copy of entire site. So I can't upgrade. I tried also with the automatic live update and manual install.
can you help me?
thanks
8 years 10 months ago #4 by 810
1) Issue with template, change the template
2) You have a conflict with a plugin. Unpublish all none joomla/kunena plugins, and look if its works.
For the update, You should enable the error messages on joomla configurations, Set to max and you will see where the error is coming from.
8 years 10 months ago #5 by uolly78
OK it works
Now I have Kunena Version 4.0.0 but i have the same issue with the underscored text :(
8 years 10 months ago #6 by 810
any link
8 years 10 months ago #7 by uolly78
Here is a test forum
www.astrotrieste.it/work/index.php?optio...emid=278&layout=list
you can acces with
username: kunena
passwork: kunena
thaaaaaaaaaaaaaaaaaaaaanks :woohoo: :woohoo: :woohoo:
8 years 10 months ago #8 by 810
8 years 10 months ago #9 by uolly78
ok removed
but the issue persists :(
8 years 10 months ago #10 by uolly78
but you are right, it is not a kunena issue. Also in my contact form i see underscored text :blush:
Time to create page: 0.555 seconds
