Kunena 7.0.3 Released
The Kunena team has announce the arrival of Kunena 7.0.3 [K 7.0.3] in stable which is now available for download as a native Joomla extension for J! 5.4.x/6.0.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 7.0
Solved Writing topics always with underscore
10 years 10 months ago #165330 by uolly78
Hello to all!
Every time I write a topic or a reply in my Kunena, the text is always underscored. When the topic is published it is written correctly but when I edit it is underscored (see attached screenshot)
why?
can someone help me?
Joomla! 2.5.27 Kunena 2.0.4
10 years 10 months ago #165332 by 810
Sorry Kunena 2, is not supported anymore, please update to K4.0
The following user(s) said Thank You: uolly78
10 years 10 months ago #165333 by uolly78
Hello I have tried to update many times but the installation fails and blocks ALL THE SITE (when i type my site urls both for front end and administrator i get a completely white page after update). To restore it i have to use a backup copy of entire site. So I can't upgrade. I tried also with the automatic live update and manual install.
can you help me?
thanks
10 years 10 months ago #165334 by 810
1) Issue with template, change the template
2) You have a conflict with a plugin. Unpublish all none joomla/kunena plugins, and look if its works.
For the update, You should enable the error messages on joomla configurations, Set to max and you will see where the error is coming from.
10 years 10 months ago #165361 by uolly78
OK it works
Now I have Kunena Version 4.0.0 but i have the same issue with the underscored text :(
10 years 10 months ago #165362 by 810
any link
Time to create page: 0.312 seconds
