Kunena 7.0.8 Released
Solved [SOLVED] Kunena Menu at the bottom
11 years 1 month ago #167123 by 810
Replied by 810 on topic Kunena Menu at the bottom
yes, should be display.php
11 years 1 month ago #167124 by nickza
Replied by nickza on topic Kunena Menu at the bottom
Thank you again.
I just want to be sure, because it does not make sense as to where you suggest I place that code:
<?php /** * Kunena Component * @package Kunena.Template.Blue_Eagle * * @copyright (C) 2008 - 2015 Kunena Team. All rights reserved. * @license http://www.gnu.org/copyleft/gpl.html GNU/GPL * @link http://www.kunena.org **/ defined ( '_JEXEC' ) or die (); ?> $this->displayMenu (); -LINE 22 <div id="Kunena" class="layout container-fluid"> <?php if ($this->ktemplate->params->get('displayMenu', 1)) { $this->displayMenu (); } $this->displayLoginBox (); $this->displayBreadcrumb (); // Display current view/layout $this->displayLayout(); $this->displayBreadcrumb (); $this->displayFooter (); ?> </div>
11 years 1 month ago #167127 by 810
it should be under:
11 years 1 month ago #167134 by nickza
Working Perfectly. Thank You
11 years 2 weeks ago #168042 by nickza
Hello.
Sorry to bump this again, but after I updated to the latest version, this is not working anymore...
11 years 2 weeks ago #168044 by xillibit
Replied by xillibit on topic Kunena Menu at the bottom
Are-you still using blue eagle template ?
