Kunena 7.0.2 Released
The Kunena team has announce the arrival of Kunena 7.0.2 [K 7.0.2] in stable which is now available for download as a native Joomla extension for J! 5.3.x/5.4.x/6.0.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 7.0
Solved A new topic or answer is not posted (visible)
10 years 10 months ago #164894 by 810
its not the joomla template, also not kunena.
I think its a broken plugin. Could you check yourself.
By disable all none joomla / kunena plugins.
Then try to login on the kunena login. Now you can't also login
10 years 10 months ago #164896 by Beddesprei
i disabled all none joomla and kunena plugins but i can'st still kunena login
10 years 10 months ago #164901 by Beddesprei
I un-installed the Kunenacomponent and also the database. I install a new version of Kunena. But the problem is still the same. I can't make a reply/answer or change profiles.
(I have now been put back the backup)
10 years 10 months ago #164904 by 810
yeah, its a js conflict with some plugin.
could you test with a new joomla site, then copy the joomla users/user_usergroups, and kunena tables.
Then install kunena package.
Look if you can post.
If yes, install the joomla template. and try again.
10 years 10 months ago #164907 by Beddesprei
I have installed a new joomla version. I can answer on a topic. Only i get a error on the Kunena login: Waarschuwing
U heeft geen toegang tot het privégedeelte van deze website.
10 years 10 months ago #164908 by 810
mhh, check docs.joomla.org/J2.5:Users_Cannot_Login_in_2.5.13
or check permission on the user groups
Time to create page: 0.230 seconds
