- Thank you received: 1425
Kunena 7.0.8 Released
Solved A new topic or answer is not posted (visible)
11 years 3 months ago #164881
by 810
Replied by 810 on topic A new topic or answer is not posted (visible)
[*confidential]test [/confidential] without the * , then it will be only visible for us.
- Beddesprei
- Junior Member
11 years 3 months ago #164891
by Beddesprei
Replied by Beddesprei on topic A new topic or answer is not posted (visible)
ok Please Log in or Create an account to join the conversation.
11 years 3 months ago #164894
by 810
its not the joomla template, also not kunena.
I think its a broken plugin. Could you check yourself.
By disable all none joomla / kunena plugins.
Then try to login on the kunena login. Now you can't also login
- Beddesprei
- Junior Member
11 years 3 months ago #164896
by Beddesprei
i disabled all none joomla and kunena plugins but i can'st still kunena login
- Beddesprei
- Junior Member
11 years 3 months ago #164901
by Beddesprei
I un-installed the Kunenacomponent and also the database. I install a new version of Kunena. But the problem is still the same. I can't make a reply/answer or change profiles.
(I have now been put back the backup)
11 years 3 months ago #164904
by 810
yeah, its a js conflict with some plugin.
could you test with a new joomla site, then copy the joomla users/user_usergroups, and kunena tables.
Then install kunena package.
Look if you can post.
If yes, install the joomla template. and try again.
Time to create page: 0.244 seconds
