Solved Modify the adress
11 years 8 months ago #162777 by lemiran
Modify the adress was created by lemiran
Hi everybody
I have a J3 site with latest kunena (downloaded today).
When i publish a menu item linking to the forum, it displays this in the adress:
www.scaprin26.com/kunena/index
How could i change the "kunena" to forum for exemple?
Thank you very much
Regards Miran
11 years 8 months ago #162779 by 810
Replied by 810 on topic Modify the adress
can you add the kunena report. Copy paste here.
backend - kunena - tools - report
11 years 8 months ago #162780 by lemiran
Replied by lemiran on topic Modify the adress
Hi !
here it is:
htaccess: Exists | PHP environment: Max execution time: 300 seconds | Max execution memory: 512M | Max file upload: 64M
Joomla default template details : yoo_nite | author: YOOtheme | version: 1.0.2 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.7 | creationdate: 2015-02-01
Kunena version detailed: Kunena 3.0.7 | 2015-02-01 [ Galah ]
Plugins: Content - Kunena Discuss 3.0.7
Modules: Kunena Login 3.0.1
11 years 8 months ago #162782 by xillibit
Replied by xillibit on topic Modify the adress
You need to edit the alias of the parent menu item in Kunena menu :
The following user(s) said Thank You: lemiran
11 years 8 months ago #162783 by 810
the menu item is not correct,
please recreate menu.
backend - kunena - tool - menu - fixmenu
Then you will have a menu item called forum on the mainmenu. Enable that item. And then it should work.
If you use a other menu type, then move the item into there
11 years 8 months ago #162850 by lemiran
Thank you it was that!
My forum menu works now ;)
best regards
