Solved Kunena Menu Not Displaying until Item clicked within Forum
11 years 4 months ago - 11 years 4 months ago #161813 by robtudor
I've just upgraded my site from Joomla 1.5 to 3.4 and Kunena to the latest version and I find that when first entering Kunena, the Kunena menu does not display. As soon as I click on one of the forum categories the menu appears.
I've tried deleting the Kunena menus and then rebuilding it in the Tools facility but to no avail.
Database collation check:
The collation of your table fields are correct
Joomla! SEF: Enabled | Joomla! SEF rewrite:
Disabled | FTP layer: Disabled |
htaccess:
Exists | PHP environment: Max execution time: 3600 seconds |
Max execution memory: 512M | Max file upload: 250M
Joomla default template details :
js_impacto | author: Joomlashack | version: 3.1.9 |
creationdate: Unknown
Kunena default template details
Blue Eagle | author: Kunena Team | version: 3.0.6 |
creationdate: 2014-07-28
Kunena version detailed:
Kunena 3.0.6 | 2014-07-28 [ Tala ]
Third-party
components:
Jomsocial 3.2.1.5
Third-party SEF
components:
None
Plugins: None
Modules: Kunena Login 3.0.1
Last edit: 11 years 4 months ago by 810.
11 years 4 months ago #161814 by 810
on this report, i can see that the menu is wrong. Please try again.
Forum item type must be "menu alias" with kunena selected
The following user(s) said Thank You: robtudor
11 years 4 months ago #161823 by robtudor
Thanks 810.
That solved it.
There was another quirk. When a member logged out while in the forum they would be left with a log-in module displayed. If they attempted to use that log-in module they would not be logged in. Turned out I needed to put a "." in front of the cookie domain and all then worked. That also fixed the problem of someone clicking the link in the email for a forum notification and being told they needed to log-in even though they were already logged in. (The URL in the email notification did not have www at the front)
Time to create page: 0.351 seconds
