Kunena 7.0.8 Released
Solved Kunena menu problems: menu disappeared after updating Joomla 3.3.6
- patchworker
11 years 8 months ago - 11 years 8 months ago #161252
by patchworker
Hi guys,
I updated my joomla from 2.5.28 to 3.3.6. Everything was finde including kunena, but in the backend my control-center was not available, so I replaced /libraries and /administrator/components/com_admin/sql/updates with the original files from the full package.
Now, my control-center is available, every other thing works fine, except for kunena
There ist no kunena in frontend, neither in backend.
Frontend says: closed for maintenance
Backend says: Fatal error: Class 'KunenaForum' not found in .../administrator/components/com_kunena/install/model.php on line 1363
But I did not do anything in the com_kunena?! I only replaced /libraries and .../update in com_admin/...
Don't want to reinstall kunena and lose the settings and all the posts from the members.
Is this a known issue?
Anybody here can help me?
Thanks in advance!
patchworker.
Thanks in advance!
patchworker.
Last edit: 11 years 8 months ago by 810.
11 years 8 months ago #161253
by 810
Replied by 810 on topic Kunena menu problems: menu disappeared after updating Joomla 3.3.6
uninstall kunena. (all settings and messages still will be there) Then install the lasted version.
- patchworker
11 years 8 months ago - 11 years 8 months ago #161255
by patchworker
Replied by patchworker on topic Kunena menu problems: menu disappeared after updating Joomla 3.3.6
Last edit: 11 years 8 months ago by patchworker. Reason: missing attachment
11 years 8 months ago #161256
by 810
i would say:
all.
Then install kunena again and the kunena language pack.
all.
- patchworker
11 years 8 months ago #161257
by patchworker
bingo - that's it! Many Thanks!
In the former version in the frontend I had three tabs e.g. "current". Now they are gone.
Where can I acitvate them?
Thanks again for your fast help!
patchworker.
patchworker.
11 years 8 months ago #161258
by 810
you mean, index recent topics search?
go to backend - menu - mainmenu - enable forum item.
Time to create page: 0.268 seconds
