Kunena 7.0.8 Released
Solved ReCAPTCHA Won't Remove
11 years 8 months ago #160972
by seamt1982
ReCAPTCHA Won't Remove was created by seamt1982
I have Joomla 3.2.7 website with Kunena Forum 3.0.6. I currently cannot remove the captcha. This is very frustrating. In the Joomla configuration I made sure captcha is turned to "non selected." In Kunena I made sure Config > Security > CAPTCHA Challenge for Guests is set to NO. I also made sure Captcha - ReCaptcha is turned off.
For some reason, when making a new post within the forum, the Captcha still shows.
11 years 8 months ago #160973
by 810
Replied by 810 on topic ReCAPTCHA Won't Remove
try to remove cache
11 years 8 months ago #160990
by xillibit
Replied by xillibit on topic ReCAPTCHA Won't Remove
Are-you using the default Kunena template ?
11 years 8 months ago #161045
by seamt1982
Replied by seamt1982 on topic ReCAPTCHA Won't Remove
Yes, I am using the default Kunena Template which is: Blue Eagle.
11 years 8 months ago #161065
by xillibit
Are-you using cache somewhere in Kunena ?
11 years 8 months ago #161077
by seamt1982
No, I am not using cache anywhere within this website.
Any other ideas?
Any other ideas?
