Solved Avatar not showing in topic
11 years 11 months ago - 11 years 11 months ago #160891 by zeehond
I am using Kunena 3.0.6 and having an issue with the appearance of the avatars. It is showing on the profile, in category and topic it only shows a link to the user profile (showing avatars is enabled in backend).
I checked the files in the different folders for resized images, only the folder for size 200 contains avatar images. The others are empty, so there are no thumbs created. All folders have chmod 777, that should not be the problem.
I have tried using Gravatar but that will only show the blue gravatar image and not the uploaded avatar. I noticed also the the Kunena gallery is empty, that should not be, should it?
Does anybody know what causes this?
Last edit: 11 years 11 months ago by 810.
11 years 11 months ago #160894 by 810
Replied by 810 on topic Avatar not showing in topic
Go the kunena config - frontend- set Show Avatar on Category Index and Recent Topics to "Yes".
Yes the kunena gallery is empty by default.
11 years 11 months ago #160895 by zeehond
Replied by zeehond on topic Avatar not showing in topic
That one is already set to Yes, but thank you
11 years 11 months ago #160896 by 810
could you paste here the kunena report:
backend - kunena - tools -report
11 years 11 months ago - 11 years 11 months ago #160897 by zeehond
Joomla! SEF: Enabled | Joomla! SEF rewrite: Enabled | FTP layer: Enabled |
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 256M | Max file upload: 32M
Joomla default template details : protostar | author: Kyle Ledbetter | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.6 | creationdate: 2014-07-28
Plugins: None
Last edit: 11 years 11 months ago by zeehond.
11 years 11 months ago #160898 by 810
could you enable the forum menu-item. so i can check the forum on the site.
The following user(s) said Thank You: zeehond
