Solved Avatars don't show on latest posts
11 years 10 months ago #160295 by MerlinMal
added my avatar pic and shows fine in forums, on latest posts the avatar pic was empty, tried to change settings but now i just get a standard blue image on all posts
This is my 2nd website with your forum and i have the same problem on both
Quite new to website building
11 years 10 months ago #160300 by rich
1. Go in backend to "Kunena > Plugins" and disable the plugin Kunena - Gravatar Integration
2. Kunena "Configuration > Frontend" and set "Show Avatar on Categoriy Index and Recent Topics = Yes"
The following user(s) said Thank You: MerlinMal
11 years 10 months ago #160301 by MerlinMal
Thankyou so much buddy, worked a treat!
Is there a pm system that connects with kunena?
joomla only give u admin pms, uddelm collapsed on my 1st site and there's no support whatsoever
11 years 10 months ago - 11 years 10 months ago #160302 by rich
Uddeim works. You must enable the plugin "Kunena - Uddeim Integration"
You find help in the Uddeim readme file.
Last edit: 11 years 10 months ago by rich.
11 years 10 months ago #160303 by sozzled
