Solved Avatar not see
11 years 7 months ago - 11 years 7 months ago #159589 by Pinacolado
Avatar not see was created by Pinacolado
Hi everyone, i have some problem Kunena avatar i can't see it. Source code and admin panel great works, but interface dont show.
Do you have a clue? Can you help me? Thanks.
sample images : prntscr.com/4ur7pl
Now i fix this problem. Again thanks
Problem is - TMlazyload
How to fix - prntscr.com/4urb4b
Last edit: 11 years 7 months ago by 810.
11 years 7 months ago #159640 by adarkwa
Replied by adarkwa on topic Avatar not see
i think i have the same problem can someon one help us
The following user(s) said Thank You: Pinacolado
11 years 7 months ago - 11 years 7 months ago #159643 by 9themestore
Replied by 9themestore on topic Avatar not see
Hi all,
The first you should check the existence of the avatar image. If that image exists in the avatar folder, It is caused by conflict CSS between your Joomla! and Kunena template. I can hep you check and debug if if you provide me a test account.
Regards
Last edit: 11 years 7 months ago by 9themestore.
11 years 7 months ago #159692 by Pinacolado
Replied by Pinacolado on topic Avatar not see
TMLazy load need closed. i not understand why but they are not work with together. @9themestore yeap if you want to check it can i give you test account.
Soon i will do it. Thanks
Time to create page: 0.268 seconds
