Solved [gelöst] Kunena Code Highlighting
12 years 2 months ago - 12 years 2 months ago #159161 by Snblchn
I'm sorry to annoy you with my topic, but i do not see the problem.
(Kunena Version 3.0.6)
My Problem is, that i do have the Code Syntax Highlighting set to Yes (enabled) and it's not working and how can i switch between programming-languages.
I do see the "raw-Code" highlights (orange Box, but no Highlights at all)
System.out.println("hello");
Just like this one ( www.kunena.org/forum/159-K-17-Common-Que...le-code-highlighting )
Thanks for your help,
Xhri
Last edit: 12 years 2 months ago by Snblchn.
12 years 2 months ago #159162 by rich
This function is not included by default in Joomla 2.5 and 3.x. You need the Joomla-GeSHi plugin so that it work.
www.geoffhayward.eu/blog/the-secret-of-j...i-syntax-highlighter
The following user(s) said Thank You: Snblchn
12 years 2 months ago #159202 by Snblchn
Thanks, that's all i wanted to know.
