Solved Topic character limit in latest topics [SOLVED]
11 years 9 months ago - 11 years 9 months ago #158740 by Kotsolis
I did it. Maintenance-Clear Cache to everything, then deleted cookies, history etc. (everything) and again the same thing.
Last edit: 11 years 9 months ago by Kotsolis.
11 years 9 months ago - 11 years 9 months ago #158816 by Kotsolis
Hello Iam still waiting for a reply on this.
I will copy-paste my configuration in this topic as well. My configuration shows this error message
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '-08-2014' at line 1 SQL=SHOW FULL FIELDS FROM jos_kunena_messages29-08-2014
Configuration is:
Database collation check:
htaccess: Exists | PHP environment: Max execution time: 7200 seconds | Max execution memory: 1024M | Max file upload: 1024M
Joomla default template details : whiteboard | author: Opensource | version: 2.6 | creationdate: Unknown
Third-party components: Jomsocial 3.1.0.1
Plugins: Search - Kunena Search 3.0.1 | JomSocial - My Kunena Forum Menu 2.0.3 | JomSocial - My Kunena Forum Posts 2.0.3 | JomSocial - Kunena Groups 2.0.3
Modules: Kunena Latest 3.0.1 | Kunena Search 3.0.1
11 years 9 months ago #158820 by 810
1) looks like a bug in lasted module.
2) www.gameworld.gr/kunena/27-games here you see that's working.
3) jos_kunena_messages29-08-2014 is not correct. please fix it in your database.
Time to create page: 0.236 seconds
