Solved Impossible upload images
11 years 9 months ago #158388 by mlamer
Hello to everybody,
I have a concern, it is that it is impossible to insert images with the function(office) "accompanying documents" as here.
By putting down(By depositing) the image somewhere and by giving the link OK.
Otherwise, everything takes place normally, no error message, but no posted(shown) image...
My url:
www.artphotoroussillon.fr
Mp : test
11 years 9 months ago #158391 by xillibit
Replied by xillibit on topic Impossible upload images
When you do an upload not the time and check in apache error log or php error log if you have a corresponding issue. You can access to it by hosting control panel.
11 years 9 months ago #158392 by mlamer
Replied by mlamer on topic Impossible upload images
:( I have no access to these files to my host.
11 years 9 months ago - 11 years 9 months ago #158396 by mlamer
Hello everybody,
I have a strange problem with my Kunena forum (v 3.0.6) on an Joomla V 2.5.xx (tu met ta version Joomla exacte).
I can not post a picture, nor an image neither a pdf file even a little one. When setting the Joomla error message to maximum value, I got no error message. There is only no visible file after the operation.
Can you help me I have no more idea ?
My configuration:
htaccess: Exists | PHP environment: Max execution time: 50 seconds | Max execution memory: 128M | Max file upload: 96M
Joomla default template details : ashton | author: Globbers | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.6 | creationdate: 2014-07-28
Plugins: Search - Kunena Search 3.0.1 | Content - Kunena Discuss 3.0.1
Modules: Kunena Latest 3.0.1 | Kunena Stats 3.0.1 | Kunena Login 3.0.1 | Kunena Search 3.0.1
My accommodation(hosting) is made to one.com
Best Regards
Last edit: 11 years 9 months ago by mlamer.
11 years 9 months ago #158403 by mlamer
11 years 9 months ago #158422 by xillibit
What you host say about this issue ?
