Solved Kunena 3.0.6 Joomla 3.3.3 Fresh install 404 Error
11 years 9 months ago - 11 years 9 months ago #158184 by opiokane
Thank you for the great component.
I freshly install Kunena 3.0.6 on Joomla 3.3.3
My settings are
Joomla : SEF =yes, mod_rewrite=yes, .htaccess copied directly from htaccess.txt provided by Joomla team.
Kunena : SEF = yes
Then I get 404 not found error when I click default kunena menu link.
If I turn off SEF on Joomla it works but when I have SEF on Joomla turned on I get 404 not found error.
All my other menu items than Kunena work fine. I also checked whether mod_rewrite is working or not and it works fine.
My site is
www.ibrary.co.kr
menu item for the forum is on the left most on the top menu, identified by "forum"
If you have any idea please help me.
TIA
I solved the problem by creating menu item which is a system link to the Kunena menu.
Thanks!
Last edit: 11 years 9 months ago by 810.
11 years 9 months ago #158190 by 9themestore
It's working fine on your site. Great component for your site.
Time to create page: 0.283 seconds
