Solved I lost the Index page by being clever
12 years 3 weeks ago #156013 by fastfoodsource
I tried to be clever and create a subdomain forum.fastfoodsource.com via my web host cpanel. Doing so seems to have deleted a file in the public_html/kunena folder. All that was there was an .htaccess file with a bunch of garbage for my botched subdomain redirect attempt.
You can see what I mean:
www.fastfoodsource.com/kunena/recent
Once on this page, click the Index tab and you will see a web folder directory, not the forum index.
I tried reinstalling Kunena but no good. I suspect an index.html file got deleted.
Any suggestions are appreciated.
12 years 3 weeks ago #156014 by 810
first remove kunenamenu. and the forum on mainmenu.
then try backend -kunena -tools - menu - restore kunena menu
12 years 3 weeks ago #156018 by fastfoodsource
OK, that did the trick.
I believe my subdomain steps had created a Kunena folder in the root directory that was conflicting with the menu. Before removing this folder (public_html/kunena), I received this error:
500 - An error has occurred.
A first level menu item alias cannot be 'kunena' because 'kunena' is a sub-folder of your joomla installation folder.
After deleting that folder, which only contained the previously-deleted suspect .htaccess file and an empty cgi-bin folder, I was able to restore the kunena menu as directed.
All is now functioning normally.
Thank you for the quick response!
Time to create page: 0.264 seconds
