Solved Submit, Preview, and Cancel buttons missing in IE 10
For some reason I cannot see the submit, preview, and cancel button inside internet explorer 11. All other browsers are working just fine. I've tried putting in compatibility view and that still hasn't fixed the issue. Any suggestions or thoughts on why this is happening and how to resolve it? Thanks in advance!!
I tested two different sites with IE 11 (by the way, I thought that Microsoft removed the "compatibility mode" feature from the IE 11 developer's tooks (?)
I have many websites using J! 3.2 (do you mean J! 3.2.0, J! 3.2.1, J! 3.2.2 or J! 3.2.3) as well as sites using the Protostar Joomla template. I do not remember this problem when I tested Kunena with IE 10 but, because I have upgraded all my computers to IE 11, I cannot confirm if Kunena is "broken" with IE 10 or if it is not broken. I do not remember which version(s) of Microsoft Windows still use IE 10.
When I suggested that you look at the FAQs page, did you see how to produce a configuration report? It might help
